Inline Assembly - jmp
2,860件の閲覧回数
Rocko
I have loaded my App into a defined section of Flash.  I now need to run the asm_startmeup function to run the App.  The code that has loaded the App doesn't regonise asm_startmeup.  If I know the address of asm_startmeup how do I jump to it and run it?
HCS12 would be something like this....(I think):
 asm void boot_StartApp(void)
    jmp [0x00010000]
Cheers
R
1,562件の閲覧回数
Rocko
remove the brackets - jmp 0x00010000 - seems to work!
