Inc size for BCHG #6, (A2)+
2,707 次查看
tupdegrove
Test M[a2].[6]
I know this is a byte operation but is register a2 post incremented by 1 or 4 bytes?
Tim
1,883 次查看
kef
Specialist I
What's this: Test M[a2].[6] ?
All (Ax)+ like operations will increment Ax by sizeof of operand. Sizeof is 1 in your case (BCHG.B), and A2 will be incremented by 1.
1,884 次查看
kef
Specialist I
1,883 次查看
tupdegrove
Thanks Kef. Got it.  An inc by 1 makes sense if mem[a2] just represents an 8-bit value.  However, I would think the more common case on a 32-bit cpu would be to inc by 4 because mem[a2] is the ls byte of a 32-bit value.
Tim
