How to use the temperature sensor on the MCF51JM128 Coldfire
1,976 次查看
Nikolai
I am using the badge board revision C with the MCF51JM128 Coldfire on board. I could not find any documentation on using the temperature sensor. Im not even sure if there is a temperature sensor, however, i found its mention in the ADC part of the Coldfire manual. Can anybody help ?
1,104 次查看
J2MEJediMaster
Specialist I
Try entering the processor part number "MCF51JM128" into the Enter Keyword text entry box at the upper right of this web page and it will search for part-specific info. One of the documents found in this search may have the information you need. HTH.
---Tom
