How to make SD Card working on M52277EVB board
AnilM
I am using the linux kernel 2.6.23-uc1.I tried compiling a new kernel with MMC/SD card support enabled.But still not working.What all commands I need to use to check whether SD card is working or not.
Anil
mwaddel
Hi Anil,
There's a user's guide for this driver included with the iso you downloaded.
It's in Help/software/device_drivers/SDIO_MCF5227x.htm.  Did you find at
this guide?  Were there any messages during kernel boot concerning the
SD device?
Matt
AnilM
Matt,
  Thanks for the reply .I am not able to find an html page with the name you mentioned.Could you please forward that if possible
Anil
mwaddel
Here's the doc.
AnilM
Matt,
  Thanks for the info.I have downloaded the new BSP and built a new kernel and followed the procedure in the doc now it is working
Thanks Again
Anil
JimDon
Senior Contributor III
Did this turn out to be true ?
"Communication with SD/MMC cards is very slow"
AnilM
I didn't get aby message like that and I was able to access the files faster also
Anil
