HELP: Can uClinux run on 5213EVB?
2,092件の閲覧回数
winkling
I noticed that there is no external bus on 5213, so I would like to know that if uClinux can run on the 256k flash and 32k sram on the chip?
thanks.
912件の閲覧回数
JWW
Your best choice is to use eCos , which now comes with the 5213 EVB.  There are also other small RTOSs available, uclinux is not really suited for any MCU only with no bus. If you need secure flash and external bus, for uclinux, then try 5282.
-JWW
912件の閲覧回数
cdcll
Could anyone tell me if ECOS can run on 5223x and any demo available?
