Getting error for CF_Lite "couldnot find or load file LICENSE.txt for target."
1,845 次查看
TVNAIDU
Just got link for TCP/IP stack (CF_Lite3.2), downloaded and opened 7.1 project file, tried to compile, getting this "couldn't find LICENSE.txt" error, any idea?.
1,408 次查看
vier_kuifjes
Senior Contributor I
The file is included in the project files (see the file tree in the left window). Simply remove it and the error will be gone. I guess they just did that to make you take a look at it...
1,409 次查看
vier_kuifjes
