Device Initializtion Window.   I am trying to take advantage of Device Initialization in version 6.3
1,790件の閲覧回数
fsprogrammer
When I use the Pull down box to try to change from PTE to PTD etc, the ports seem to get all screwed up.  IE the port setting are now the same as the Port i just switched from.  Example - use the pull down menu in attachement to switch from PTA to PTB
2 返答(返信)
1,268件の閲覧回数
ProcessorExpert
Senior Contributor III
I have not reproduced the problem. Could you please specify what MCU are you targeting? Could you post here a step by step process to reproduce the problem?
best regards
Vojtech Filip
Processor Expert Support Team
1,268件の閲覧回数
fsprogrammer
I am using MCF51JM 128
