DMA Bus errors when reading from ADC
2,624 次查看
marksheahan
I am trying to read from the ADC at 500KHz, and store it in a buffer. Interrupts weren't fast enough, so I want to use DMA to move data from the ADC result registers into the buffer. There is a bus error on source when reading from the ADC result registers. What might be causing this?
The device is a MCF52235.
Thanks in advance,
Mark
1,834 次查看
marksheahan
Fixed, by setting master privilege register to include the DMA controller
1,834 次查看
maximevincent
Thank you so much for this!
Had to set PBRIDGE0.MPL2 = 1;
GREAT!
