Compile with mcf5207
4,633 次查看
jgiacomoni
I have a MCF5207, but I would like to compile c++ code with code warrior.
How to make this ? I just would like compiler and no ide.
Thanks a lot.
标记 (2)
5 回复数
4,459 次查看
jgiacomoni
or can I download the 6.4 compiler only?
thanks,
Jessy G;
4,451 次查看
Bio_TICFSL
is better to download the 7.2v, You can download it here:
https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
and you have to use the stationary project for MCF5208
regards
4,575 次查看
jgiacomoni
My compiler info is :
My version is :
CodeWarrior C/C++ for ColdFire.
Copyright (c) 2009, Freescale Semiconductor, Inc
All rights reserved.
Version 6.0 build 2004 (build 2004)
Runtime Built: Apr 7 2010 17:53:02
4,602 次查看
Bio_TICFSL
If you have codewarrior 6.3 or up, you have to create the project for C++ and you can build it. And you can select the MCF5208 since it have a stationary project.
4,578 次查看
jgiacomoni
Hello !
Where I can download compiler ?
