Coldfire 7.2 upgrade from V 5.7 Issues
1,199件の閲覧回数
jamesc
Fisrt off thanks in advance for any help you can send my way.
The issue i am having is that we have upgraded from CodeWarrior IDE version 5.7, ran on XP, to Coldfire 7.2 ran on a Window 7 system. I have been able to migrate all the file over for the current chip we are using, PCF52235 CAL60, without any issues when swapping to the new computer. The problem I have is when I go to debugg or make the file. It keeps telling me that "Int Handlers.h" file is missing. (Only error that comes up) I have found it on the old system, 3 different versions, but none of them work. They just give me a 16 bit error even though the chip is a 32 bit chip.
Any help you can give me would be greatly appreciated.
0 返答(返信)
