Cold fire hangs!!!!
Cold fire hangs!!!!
2,714 次查看
pass
Hello All,
i am working on coldfire 5280,
wile accessing the variable at the address 0x44400000, coldfire hangs without giving any exception,
i mappeed IPSBAR at 0x40000000 address,
can anybody tell me what is actually mapped at 0x44400000 if my IPSBAR base adderss is 0x40000000,
1,452 次查看
mvincent
There is nothing mapped at that address. Furthermore, any access to an unmapped location part of the IPSBAR range (0x40000000-0x7FFFFFFF in this case) will cause the processor to hang. Unfortunately, the bus monitor won't help you and cause a bus/access error exception in this case.
