Clock Frequency generation for MCF54415
navinshekhar
i need to generate these clock frequencies in MCF54415 cpu
Core System & SDRAM Clock250MHz
Peripheral Clock 125MHz
FB Clock100MHz
USB Bus60MHz
NAND Flash Controller80MHz
eSDHC Clock40MHz
How to set the reference clock for the same.
Thanks in advance.
TomE
Specialist II
This Forum is titled as being for "general questions regarding community interaction and/or collaboration". You should be asking this in the ColdFire Forum.
The Admins may move this question there for you.
Tom
