Big Integer Math
Big Integer Math
2,686件の閲覧回数
lolachampcar
I am doing some RSA stuff and was looking for a Big Integer math library for use in the JM128.  Please let me know if you can point me in the right direction.
Thanks!
3 返答(返信)
2,085件の閲覧回数
ElioMussini
Hi, what you need is called an arbitrary precision arithmetic library. Some time ago I coded a prototype of the DSA Digital Signature algorythm using a 16 bit freescale part, I used the MIRACL library at that time,and after some tweaking it worked great. Maybe there is something more specific for embedded processors today, but I dont know.
Elio
2,085件の閲覧回数
kef
Specialist I
How big is big? 64bits long long is supported natively in CW for MCUs when targeting Coldfire V1. Long long is 32bits wide targeting S08.
2,085件の閲覧回数
lolachampcar
I would have to go back and check but it is my divide with remainder that is giving me problems and it works on 128 byte inptus (yes, BYTES).
