Debug Memory View - Export/Inport
ITCO00
I'm using CW 10.1.3 for SmartDSP with SDOS. In the debug Memory View I do the following:
1. I export (dump) 2KB of memory data from DDR1 location to a raw binary file. This operation is OK.
2.  Then, I overwrite the first few memory locations with 0xFF,
3. Finally, I try to import the file I previously exported to the beginning of the memory location.
The Import operation does not work. If I reduce the data size to 1KB, it works OK.
In any case I've checked the exported file, and its content was correct.
What might be the problem?
Thanks.
Irene
NXP Pro Support
NXP Pro Support
Have you tried to import/export memory using Target Task option?
Irene
NXP Pro Support
NXP Pro Support
ITCO00
Thanks, I wasn't aware of this option. I've tried to create Target Task for Fill, Export and Import Memory, using hex data and physical memory, and it works fine.
thank you.
