[CW 10.1.8] Error when including breakpoint
2,622 次查看
Lo
I am trying to debug an application but for some reasons, CW crashes when I include a breakpoint at a specific location.
When i remove this breakpoint (but some others still stand), the application runs with no problem.
Do you have any idea of the cause ?
Hereafter the screenshots of the displayed error and the dumpfile.
Thank you
标记 (1)
2,208 次查看
CrasyCat
Specialist III
Hello
Did you look at following article?
      http://www.eclipsezone.com/eclipse/forums/t61566.html
It provides some tricks on how to clean up a workspace.
CrasyCat
2,208 次查看
Lo
Last time, the problem dissapeared suddenly after a while but I still got some problems...
When an error occurs during debug with a crash (screenshots attached to the previous post: 3 consecutive error messages), the project seems to be corrupted after that.
After restart, the runs crash if I try to stop at some breakpoint.
I need then to create a new workspace to avoid this problem and it takes time.
I guess there is a way to clean the workspace and i've found a link but it doesn't work for me.
http://blogs.freescale.com/2011/11/10/codewarrior-tool-tip-1-improve-performance-by-cleaning-house-i...
Thank you for your help
2,209 次查看
CrasyCat
Specialist III
Hello
CrasyCat
