CCS: Library not found
rainerhaseneder
In order to debug a DSP startup issue I have connected a Gigabit TAP to my board (3 SoC B4680) and want to download DSP SW from a Windows 7 - PC with:
CodeWarrior for StarCore
     Version: 10.8.2
     Build Id:416,
but I get systematically the error message (I can connect to my board and application SW is running):
CCSProtocolPlugin: CCS: Library not found
Has anyone got a clue how I can solve this issue ?
Thank you
Rainer
Original Attachment has been moved to: CCS-log_Library_not_found.txt.zip
lunminliang
Hello Rainer Haseneder,
The error is usually due to hardware failure. Please check the JTAG interface and related power on your board.
Lunmin
