where is my objectfile?
2,002 次查看
chuanchuan
-------------------CW for MPC555 V8.7
where is my objectfile?  It should be in the XXX_date/Debug_version, right?   but I can`t find it .
标记 (1)
939 次查看
CrasyCat
Specialist III
Hello
If you are building from the IDE, you will not see any formal object files being created. The IDE will generate either a executable or a library file according to the linker you have selected.
Single object files are not explicitly generated. THey are kept in some IDEA specific binary file.
If you want to see/generate formal object files, you will need to build your application from batch or from a make file (using command line version of the tools).
I hope this helps.
CrasyCat
939 次查看
chuanchuan
Thanks for your reply , CrasyCat, Ioud and clear!:smileyvery-happy:
