some problems when use usb codewarrior tap debug on my custom lx2080 board
ソリューションへジャンプ
2,801件の閲覧回数
gec258
my platfom:
CPU:LX2080CA
DDR: MT40A1G16
FLASH:MX25UW51245G , flash is blank.
sysclk 100M。
hardware link status :us
e usb link codewarrior,and code  warrior link my board with JTAG
when I refer to 3.2 Working with bareboard application in D:Freescale\CW4NET_v2020.06\CW_ARMv8\ARMv8\Help\Getting_Started_for_CW_ARMv8.pdf to debug my board, it always report "target connection error",
then I refer to  8.6 Board Recovery in CW4NET_v2020.06\CW_ARMv8\ARMv8\Help\PDF\ARMv8_Targeting_Manual.pdf to modify Target Init File,
        USE_SAFE_RCW= True
        # Overridden RCW source
        TA.rcw.set_source(0x9F)
        # Overridden RCW registers will be added here
        TA.rcw.set_data({1: 0x586b6b18})
        TA.rcw.set_data({2: 0x24580058})
        TA.rcw.set_data({3: 0x00000000})
        TA.rcw.set_data({4: 0x00000000})
        TA.rcw.set_data({5: 0x00000000})
        TA.rcw.set_data({6: 0xc010000})
        TA.rcw.set_data({7: 0x00000000})
        TA.rcw.set_data({8: 0x00000000})
        TA.rcw.set_data({9: 0x30001a0})
        TA.rcw.set_data({10: 0x00002580})
        TA.rcw.set_data({11: 0x00000000})
        TA.rcw.set_data({12: 0x00000096})
        TA.rcw.set_data({13: 0x00000000})
        TA.rcw.apply()​
and refer to  https://community.nxp.com/t5/Layerscape-Knowledge-Base/LX2160ARDB-How-to-configure-a-new-flash-devic...    add new  flash config. change  Target Init File :
    fl.add_device({"alias": "xspi", "name": "MX25UW51245G", "address": 0x0, "ws_address": 0x18000000, "ws_size": 0x1FFFF, "geometry": "8x1", "controller": "FSPI"})
and my board hardware CFG_RCW_SRC[3:0] set to 4'b00xx.
when I click Flash Programer,It still report connection error.
and I tryed two Codewarrior Tap box, It shows same error.
Is there anything else I can check?
2,670件の閲覧回数
gec258
此问题已解决,是我们的硬件的有个jtag复位信号没接上。
还有一个原因是 TA.rcw.set_source()参考LX2160ARM手册的Hard-coded部分,这里只能填0x0/0x1/0x2。
4 返答(返信)
2,671件の閲覧回数
gec258
2,793件の閲覧回数
June_Lu
If  it's a bare board, please set the RCW_SRC[3:0] to hard-code.
When you connect the CodeWarrior TAP, should confirm the board could complete the Power-On Reset Sequence.
LX2160A Reference Manual,
4.9.5 Power-On Reset Sequence Detailed Description, step 24, System Ready State.
4.9.6 Power-On Reset Sequence Timing
And CCS could connect the CWTAP correctly.
In the ccs, please run:
(bin) 7 % delete all
(bin) 8 % config cc cwtap:10.193.21.52//(it's your CWTAP ethernet IP)
(bin) 9 % show cc
(bin) 10 % ccs::config_chain {lx2160a dap}
(bin) 11 % display ::ccs::get_config_chain
(bin) 12 % ccs::reset_to_debug
2,792件の閲覧回数
gec258
Thank you for your reply. we will check the power-on time sequence. my CWTAP box has been connected to the PC through USB.
On ccs, execute the show cc command according to the method you provided. After waiting for a while, the time out is indicated:
2,787件の閲覧回数
June_Lu
Could you ping the CWTAP?
What's your CWTAP version?
What's your CodeWarrior IDE version?
Please confirm update it to the CodeWarrior IDE version 11.5.12.
On the NXP website
My NXP Account->Software->Software Licensing and Support->View accounts->Product List->CodeWarrior for QorIQ LS Series ARMv8 ISA->
Please download update package
com.freescale.armv8.11.5.12.GA.Win.updatesite.221209.zip
Please open CodeWarrior from C:\Freescale\CW4NET_v2020.06\CW_ARMv8\fsl_eclipse.bat, and install the update package from Help->Install New Software->Add->Archive.
And then try the ccs command again.
You could reply the case in Chinese.
%3CLINGO-SUB%20id%3D%22lingo-sub-2139784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20LX2080%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%20USB%20CodeWarrior%20Tap%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3A%3C%2FP%3E%3CP%3ECPU%3ALX2080CA%3C%2FP%3E%3CP%3EDDR%3A%20MT40A1G16%3C%2FP%3E%3CP%3EFLASH%3AMX25UW51245G%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E7%A9%BA%E7%99%BD%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3Esysclk%20100M%E3%80%82%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3Aus%3C%2FP%3E%3CP%3Ee%20USB%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A9%E3%83%AA%E3%82%A2%E3%83%BC%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A9%E3%83%AA%E3%82%A2%E3%83%BC%E3%81%AFJTAG%E3%81%A7%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ED%3AFreescale%5CCW4NET_v2020.06%5CCW_ARMv8%5CARMv8%5CHelp%5CGetting_Started_for_CW_ARMv8.pdf%20%E3%81%AE%203.2%20%E3%83%99%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%B8%B8%E3%81%AB%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8D%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gec258_0-1753326763458.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gec258_0-1753326763458.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349223i2B5441CFC67D66EB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gec258_0-1753326763458.png%22%20alt%3D%22gec258_0-1753326763458.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81CW4NET_v2020.06%5CCW_ARMv8%5CARMv8%5CHelp%5CPDF%5CARMv8_Targeting_Manual.pdf%E3%81%AE8.6%20Board%20Recovery%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%80%81Target%20Init%20File%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20USE_SAFE_RCW%3D%20True%0A%0A%20%20%20%20%20%20%20%20%23%20Overridden%20RCW%20source%0A%20%20%20%20%20%20%20%20TA.rcw.set_source(0x9F)%0A%20%20%20%20%20%20%20%20%23%20Overridden%20RCW%20registers%20will%20be%20added%20here%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B1%3A%200x586b6b18%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B2%3A%200x24580058%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B3%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B4%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B5%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B6%3A%200xc010000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B7%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B8%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B9%3A%200x30001a0%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B10%3A%200x00002580%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B11%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B12%3A%200x00000096%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.set_data(%7B13%3A%200x00000000%7D)%0A%20%20%20%20%20%20%20%20TA.rcw.apply()%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape-Knowledge-Base%2FLX2160ARDB-How-to-configure-a-new-flash-device-for-a-Layerscape%2Fta-p%2F1101353%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape-Knowledge-Base%2FLX2160ARDB-How-to-configure-a-new-flash-device-for-a-Layerscape%2Fta-p%2F1101353%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E8%A8%AD%E5%AE%9A%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-python%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20fl.add_device(%7B%22alias%22%3A%20%22xspi%22%2C%20%22name%22%3A%20%22MX25UW51245G%22%2C%20%22address%22%3A%200x0%2C%20%22ws_address%22%3A%200x18000000%2C%20%22ws_size%22%3A%200x1FFFF%2C%20%22geometry%22%3A%20%228x1%22%2C%20%22controller%22%3A%20%22FSPI%22%7D)%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2CFG_RCW_SRC%5B3%3A0%5D%E3%81%AF4'b00xx%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFlash%20Programer%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E6%8E%A5%E7%B6%9A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2%20%E3%81%A4%E3%81%AE%20Codewarrior%20Tap%20%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BB%96%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154407%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20some%20problems%20when%20%20use%20usb%20codewarrior%20tap%20debug%20on%20my%20custom%20lx2080%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154407%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E4%B8%8A%E3%81%AE%20JTAG%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E4%BF%A1%E5%8F%B7%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81TA.rcw.set_source()%20%E3%81%8C%20LX2160ARM%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%810x0%2F0x1%2F0x2%20%E3%81%AE%E3%81%BF%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20some%20problems%20when%20%20use%20usb%20codewarrior%20tap%20debug%20on%20my%20custom%20lx2080%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3ECWTAP%20%E3%81%AB%20ping%20%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3ECWTAP%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3ECodeWarrior%20IDEs%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3ECodeWarrior%20IDEs%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2011.5.12%20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3ENXP%E3%81%AE%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3E%E3%83%9E%E3%82%A4NXP%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88-%26gt%3B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2-%26gt%3B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88-%26gt%3B%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%A1%A8%E7%A4%BA-%26gt%3B%E8%A3%BD%E5%93%81%E3%83%AA%E3%82%B9%E3%83%88-%26gt%3BQorIQ%20LS%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAARMv8%20ISA%E7%94%A8CodeWarrior-%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3Ecom.freescale.armv8.11.5.12.GA.Win.updatesite.221209.zip%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3EC%3A%5CFreescale%5CCW4NET_v2020.06%5CCW_ARMv8%5Cfsl_eclipse.bat%20%E3%81%8B%E3%82%89%20CodeWarrior%20%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%5B%E3%83%98%E3%83%AB%E3%83%97%5D%20-%26gt%3B%20%5B%E6%96%B0%E3%81%97%E3%81%84%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%20-%26gt%3B%20%5B%E8%BF%BD%E5%8A%A0%5D%20-%26gt%3B%20%5B%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%5D%20%E3%81%8B%E3%82%89%E6%9B%B4%E6%96%B0%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81ccs%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3E%E3%81%93%E3%81%AECASE%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E4%B8%AD%E5%9B%BD%E8%AA%9E%E3%81%A7%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%82%82%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%20color%3A%20%23333f48%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20some%20problems%20when%20%20use%20usb%20codewarrior%20tap%20debug%20on%20my%20custom%20lx2080%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%20CWTAP%20%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%20USB%20%E7%B5%8C%E7%94%B1%E3%81%A7%20PC%20%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Eccs%20%E3%81%A7%E3%81%AF%E3%80%81%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%E6%96%B9%E6%B3%95%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20show%20cc%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E5%BE%85%E3%81%A4%E3%81%A8%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gec258_0-1753341067477.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gec258_0-1753341067477.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349275iFAD6D967D6AAF36D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gec258_0-1753341067477.png%22%20alt%3D%22gec258_0-1753341067477.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20some%20problems%20when%20%20use%20usb%20codewarrior%20tap%20debug%20on%20my%20custom%20lx2080%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%83%99%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3ERCW_SRC%5B3%3A0%5D%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ECodeWarrior%20TAP%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%91%E3%83%AF%E3%83%BC%E3%82%AA%E3%83%B3%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DLX2160ARM%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELX2160A%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E4.9.5%20%E3%83%91%E3%83%AF%E3%83%BC%E3%82%AA%E3%83%B3%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%E3%80%81%E6%89%8B%E9%A0%86%2024%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E7%8A%B6%E6%85%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E4.9.6%20%E3%83%91%E3%83%AF%E3%83%BC%E3%82%AA%E3%83%B3%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81CCS%20%E3%81%AF%20CWTAP%20%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3Eccs%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FP%3E%0A%3CP%3E%EF%BC%88%E3%83%93%E3%83%B3%EF%BC%897%EF%BC%85%E3%81%99%E3%81%B9%E3%81%A6%E5%89%8A%E9%99%A4%3C%2FP%3E%0A%3CP%3E(bin)%208%20%25%20config%20cc%20cwtap%3A10.193.21.52%2F%2F(CWTAP%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20IP)%3C%2FP%3E%0A%3CP%3E%EF%BC%88%E3%83%93%E3%83%B3%EF%BC%899%EF%BC%85cc%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FP%3E%0A%3CP%3E(bin)%2010%20%25%20ccs%3A%3Aconfig_chain%20%7Blx2160a%20dap%7D%3C%2FP%3E%0A%3CP%3E(bin)%2011%20%25%20%E8%A1%A8%E7%A4%BA%20%3A%3Accs%3A%3Aget_config_chain%3C%2FP%3E%0A%3CP%3E(%E3%83%93%E3%83%B3)%2012%20%25%20ccs%3A%3Areset_to_debug%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
