no BSP code after installing BSP/ltib package?
1,838 次查看
KurtZou
Hi all,
I've downloaded MPC85xx BSP/ltib package from this site. After intall ,there's no BSP code?where can I find that:robotvery-happy:
标记 (1)
1,036 次查看
KurtZou
Thanks genuap! this really helps.
One more question, where's u-boot source code? I think source under ..../rpm/BUILD/linux is kernel code right?
1,036 次查看
genuap
After you install the ltib, you need to go into the installation directory and configure it - run the ltib GUI:
./ltib -c
Then you can select which packages you want, what you want in the kernel etc... This'll take a while - because it has to extract all of the packages, and compiles them. When it's done, you can find the source in:
 /ltib_intsll/rpm/BUILD/linux/
