T2080RDB-PC Board Program Flash for the First Time without U-Boot
1,124件の閲覧回数
asnovice_ad
Hello, I am trying to load u-boot onto the T2080RDB board for the first time. From what I've understood, I downloaded the SDK files. From here, I got the pre-compiled uboot files.
On CodeWarriors, I have created a new project with SRAM settings. It uses the T2080RDB-PCle_init_sram.tcl as hte initialization target script.
I run the debug configuration over to attach to the board. Then I run the flash programmer in the preset SPI flash config and used u-boot-spi-2016.01+fslgit-r0.bin to download onto the board. I tried with offset of 0xFFF4000 but that always failed, it works if I don't specify an offset.
At this point I change the PC to 0xFFFFFFFC but there's nothing loaded there so nothing happens. I'm assuming I'm doing something terribly wrong here. Some guidance will be greatly appreciated.
Also, in the subsequent instructions on the quick start, I cannot find a file for t2080.rcw, can you point me to where I can get the right one? I just need a default to get something working. For the other files I've used the following:
 - u-boot-nor-2016.01+fslgit-r0.bin (for u-boot.bin)
 - cs4315-cs4340-PHY-ucode.txt (for cs4315-ucode.txt)
 - fsl_fman_ucode_t2080_r1.1_108_4_5.bin (for fman_ucode.bin)
1,055件の閲覧回数
Bio_TICFSL
For a first-time load on the T2080RDB-PC, the common "terrible wrong" is usually the Reset Configuration Word (RCW). Without a valid RCW in flash, the processor doesn't know how to configure its clocks or where to find the bootloader, leading to the "nothing happens" state you're seeing.
The RCW isn't a single "one-size-fits-all" file; it depends on your boot source (SPI, NOR, SD).
  • In the SDK: Look in the Yocto build directory: tmp/deploy/images/t2080rdb-64b/.
  • In U-Boot Source: If you have the source, check board/freescale/t208xrdb/ for files like t2080_spi_rcw.cfg.
  • Standard RCW Override: If the board is "blank," you must use a JTAG RCW Override in CodeWarrior. This "tricks" the CPU into a working state so you can program the flash. Look for .cfg files in your CodeWarrior installation folder under:
    {CW_Install_Path}\PA\Config\jtag_chains\T2080RDB_RCW_override.cfg.
Instead of attaching and manually moving the PC, follow this standard "un-bricking" flow:
  1. Set DIP Switches: Configure for Hard-coded RCW or a known boot override (e.g., SW1: 0100 1110, SW2: 1011 1111, SW3: 1100 0001).
  2. Use Flash Programmer:
    • Load your u-boot-spi-*.bin at Offset 0.
    • Load your RCW binary at Offset 0 (the SPI image usually includes the RCW at the front)
1,056件の閲覧回数
Bio_TICFSL
1,021件の閲覧回数
asnovice_ad
Appreciate it! I had the RCW loaded at the wrong address, u-boot worked after fixing it
%3CLINGO-SUB%20id%3D%22lingo-sub-2336732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EU-Boot%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%ABT2080RDB-PC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%88%9D%E3%82%81%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E5%88%9D%E3%82%81%E3%81%A6T2080RDB%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABu-boot%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E9%99%90%E3%82%8A%E3%81%A7%E3%81%AF%E3%80%81%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fembedded-software%2Flinux-software-and-development-tools%2Flinux-sdk-for-qoriq-processors%3ASDKLINUX%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%26amp%3B_gl%3D1*d6xo81*_ga*MTc5NzkyMDk0Ny4xNzczOTI5MDk0*_ga_WM5LE0KMSH*czE3NzM5MjkwOTMkbzEkZzAkdDE3NzM5MjkwOTMkajYwJGwwJGg5MDUzODk4Mjk.%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3ESDK%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%3C%2FA%3E%3C%2FSPAN%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AEU-Boot%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3ECodeWarriors%E4%B8%8A%E3%81%A7%E3%80%81SRAM%E8%A8%AD%E5%AE%9A%E3%82%92%E5%90%AB%E3%82%80%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6T2080RDB-PCle_init_sram.tcl%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%97%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AESPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%A7%8B%E6%88%90%E3%81%A7%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81u-boot-spi-2016.01%2Bfslgit-r0.bin%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%920xFFF4000%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%B8%B8%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7PC%E3%82%920xFFFFFFFC%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E4%BD%95%E3%82%82%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8B%E3%81%B2%E3%81%A9%E3%81%8F%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%AF%E3%80%81t2080.rcw%20%E3%81%A8%E3%81%84%E3%81%86%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%81%A9%E5%88%87%E3%81%AA%E3%82%82%E3%81%AE%E3%82%92%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%A8%E3%82%8A%E3%81%82%E3%81%88%E3%81%9A%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%93%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20-%20u-boot-nor-2016.01%2Bfslgit-r0.bin%20(u-boot.bin%E7%94%A8)%3CBR%20%2F%3E-%20cs4315-cs4340-PHY-ucode.txt%20(cs4315-ucode.txt%20%E7%94%A8)%3CBR%20%2F%3E-%20fsl_fman_ucode_t2080_r1.1_108_4_5.bin%20(fman_ucode.bin%20%E7%94%A8)%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2337688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2080RDB-PC%20Board%20Program%20Flash%20for%20the%20First%20Time%20without%20U-Boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CDIV%3ET2080RDB-PC%E3%81%B8%E3%81%AE%E5%88%9D%E5%9B%9E%E3%83%AD%E3%83%BC%E3%83%89%E6%99%82%E3%81%AB%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E3%80%8C%E9%87%8D%E5%A4%A7%E3%81%AA%E3%83%9F%E3%82%B9%E3%80%8D%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%A7%8B%E6%88%90%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%88RCW%EF%BC%89%E3%81%A7%E3%81%99%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AARCW%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%82%84%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E5%A0%B4%E6%89%80%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%A8%E3%81%97%E3%81%A6%E3%80%8C%E4%BD%95%E3%82%82%E8%B5%B7%E3%81%93%E3%82%89%E3%81%AA%E3%81%84%E3%80%8D%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEICBAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3ERCW%E3%81%AF%E5%8D%98%E4%B8%80%E3%81%AE%E3%80%8C%E4%B8%87%E8%83%BD%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%88SPI%E3%80%81NOR%E3%80%81SD%EF%BC%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEICRAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3ESDK%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%20Yocto%20%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3Etmp%2Fdeploy%2Fimages%2Ft2080rdb-64b%2F%3C%2FCODE%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEICRAB%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3EU-Boot%20Source%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%9A%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3Eboard%2Ffreescale%2Ft208xrdb%2F%3C%2FCODE%3E%E3%81%A7%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3Et2080_spi_rcw.cfg%3C%2FCODE%3E%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEICRAC%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E6%A8%99%E6%BA%96RCW%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%EF%BC%9A%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%80%8C%E7%A9%BA%E7%99%BD%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81CodeWarrior%E3%81%A7JTAG%20RCW%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFCPU%E3%82%92%E3%80%8C%E3%81%A0%E3%81%BE%E3%81%97%E3%81%A6%E3%80%8D%E5%8B%95%E4%BD%9C%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%99%E3%82%8B%E4%BB%95%E7%B5%84%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E.cfg%3C%2FCODE%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84CodeWarrior%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%86%85%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9A%3CBR%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-pl%3D%22%7C%5B%5D%22%20data-sfc-root%3D%22c%22%20%2F%3E%20%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%7BCW_Install_Path%7D%5CPA%5CConfig%5Cjtag_chains%5CT2080RDB_RCW_override.cfg%3C%2FCODE%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEICxAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3EPC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E6%89%8B%E5%8B%95%E3%81%A7%E7%A7%BB%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%E3%80%8C%E5%BE%A9%E6%97%A7%E3%80%8D%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%0A%3COL%20class%3D%22IaGLZe%20VimKh%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIDBAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%83%87%E3%82%A3%E3%83%83%E3%83%97%E3%83%BB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%A8%AD%E5%AE%9A%EF%BC%9A%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9FRCW%E3%81%BE%E3%81%9F%E3%81%AF%E6%97%A2%E7%9F%A5%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%EF%BC%88%E4%BE%8B%EF%BC%9ASW1%EF%BC%9A%20%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E0100%201110%3C%2FCODE%3E%20%E3%80%81SW2%EF%BC%9A%20%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E1011%201111%3C%2FCODE%3E%20%E3%80%81SW3%EF%BC%9A%20%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E1100%200001%3C%2FCODE%3E%20%EF%BC%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22IvUHyb_3a%2CIvUHyb_3b%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DIvUHyb_39%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIDBAD%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3EFlash%20Programmer%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%EF%BC%9A%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22IvUHyb_3h%2CIvUHyb_3i%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DIvUHyb_3g%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIDBAG%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%3CCODE%20class%3D%22o8j0Mc%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3Eu-boot-spi-*.bin%3C%2FCODE%3E%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIDBAH%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880%E3%81%ABRCW%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88SPI%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E5%85%88%E9%A0%AD%E3%81%ABRCW%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2080RDB-PC%20Board%20Program%20Flash%20for%20the%20First%20Time%20without%20U-Boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81RCW%E3%82%92%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E3%82%89u-boot%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E
