Mixed C & Assembly view when debugging
1,845件の閲覧回数
CLincoln
Sorry for littering the boards with all of these nube questions. I've done some cursory searching of the forums and help files but haven't found the answer...
When debugging a C based project, is it possible to set a breakpoint on a C statement, but switch to the assembled code and step through the low level instructions?  Using CW 4 CF 6.4.
Alternately, what is the method of viewing the C compiler's generated code?
TIA,
Chris L.
タグ(1)
1,065件の閲覧回数
Technoman64
When have started a debug session you can use the "Data" menu to select "Disassembly" or "Mixed Assembly, C code" and the view will show the assembly instructions that were generated by the compiler.
