INTC_InstallINTCInterruptHandler
2,474件の閲覧回数
SeanW
How do you use the function in IntcInterrupts.c  -->
 INTC_InstallINTCInterruptHandler(INTCInterruptFn handlerFn, unsigned short vectorNum, unsigned char psrPriority);
I am trying to build a table of vector interrupts for the INTC module and can't get them to work. Any insight into how to use the intcinterrupts.c file would be great!
タグ(1)
1,099件の閲覧回数
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
