Getting started with ColdFire C++, having problems compiling
2,505 次查看
Intrepid
I am just starting out with CodeWarrior for Coldfire (5235).
1. I create a new project and select Coldfire stationary
2. I expand the CF_M5235EVB tab and select CPP
3. I try to build the project without modification and get a ton of errors starting with "unidentified identifier 'namespace'" and a bunch of syntax errors on templates.
It does not appear to be compiling as C++. I would assume that the stationary should compile without modification. What am I missing?
John
标记 (1)
1,473 次查看
J2MEJediMaster
Specialist I
Are you using the Special or Standard Edition of Codewarrior? C++ support is only available in the Professional Edition of the Coldfire product.
---Tom
1,473 次查看
Intrepid
Tom,
That explains it! Perhaps those options should be grayed out in the special edition?
Thanks!
John
