fl::target -lc "Power1021Bare_OCRAM_Connect-core0_OCRAM_LS1021ATWR_Connect" fl::target -b 0x10000000 0x10000 fl::target -v off -l off cmdwin::fl::device -d "S29GL512N" -o "32Mx16x1" -a 0x60000000 0x63ffffff cmdwin::fl::image -f "/home/qoriqsdk/workspace/Power1021_Config3/Generated_Code/PBL.bin" -t "Binary/Raw Format" -re off -oe on -o 0x60000000 cmdwin::fl::erase image Beginning Operation ... ------------------------- Performing target initialization ... Downloading Flash Device Driver ... Reading flash ID ... Erasing Sector 0x60000000 to 0x6001FFFF Erasing ... Erase Command Succeeded cmdwin::fl::write verify Beginning Operation ... ------------------------- Programming file /home/qoriqsdk/workspace/Power1021_Config3/Generated_Code/PBL.bin Downloading Flash Device Driver ... Reading flash ID ... Downloading 0x00000070 bytes to be programmed at 0x60000000 Executing program with verify .... Program with Verify Command Succeeded cmdwin::fl::image -f "/home/qoriqsdk/QorIQ-SDK-V1.9-20151210-yocto/build_ls1021atwr/tmp/deploy/images/ls1021atwr/u-boot-ls1021atwr.bin" -t "Binary/Raw Format" -re off -oe on -o 0x60100000 cmdwin::fl::erase image Beginning Operation ... ------------------------- Downloading Flash Device Driver ... Reading flash ID ... Erasing Sector 0x60100000 to 0x6011FFFF Erasing Sector 0x60120000 to 0x6013FFFF Erasing Sector 0x60140000 to 0x6015FFFF Erasing Sector 0x60160000 to 0x6017FFFF Erasing .... Erase Command Succeeded cmdwin::fl::write verify Beginning Operation ... ------------------------- Programming file /home/qoriqsdk/QorIQ-SDK-V1.9-20151210-yocto/build_ls1021atwr/tmp/deploy/images/ls1021atwr/u-boot-ls1021atwr.bin Downloading Flash Device Driver ... Reading flash ID ... Downloading 0x0000D5C4 bytes to be programmed at 0x60100000 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x00002A3C bytes to be programmed at 0x6010D5C4 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x0000D5C4 bytes to be programmed at 0x60110000 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x00002A3C bytes to be programmed at 0x6011D5C4 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x0000D5C4 bytes to be programmed at 0x60120000 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x00002A3C bytes to be programmed at 0x6012D5C4 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x0000D5C4 bytes to be programmed at 0x60130000 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x00002A3C bytes to be programmed at 0x6013D5C4 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x0000D5C4 bytes to be programmed at 0x60140000 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x00002A3C bytes to be programmed at 0x6014D5C4 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x0000D5C4 bytes to be programmed at 0x60150000 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x00002A3C bytes to be programmed at 0x6015D5C4 Executing program with verify .... Program with Verify Command Succeeded Downloading 0x0000721C bytes to be programmed at 0x60160000 Executing program with verify .... Program with Verify Command Succeeded |
