Coldfire EWL_C Build Error
1,852 次查看
wcc3
I need to rebuild the Coldfire v2 library to change the settings.  So I switched on three things in {stuff}\Coldfire_Support\ewl\EWL_C\include\coldfire\ansi_prefix.CF.h, imported the project from {stuff}\Coldfire_Support\ewl into  CW10.2, and hit the Build button.
It built that way under 10.1, but not so much this time.  The build leaves the following warning in the Problems view:
Invalid project path:  Duplicate path entries found (/coldfire_lib/EWL_C [Output path]), path: [/coldfire_lib/EWL_C].
The Console view shows:
**** Build of configuration CF_EWL_C for project coldfire_lib ****
C:\Freescale\CW MCU v10.2\gnu\bin\make -f EWL_C.CF.mak -j16 all cleanobj
make -f EWL_C.CF.mak TARGET=v1/libc
make[1]: Entering directory `C:/Freescale/CW MCU v10.2/MCU/ColdFire_Support/ewl/EWL_C'
make[1]: `../lib/v1/libc.a' is up to date.
make[1]: Leaving directory `C:/Freescale/CW MCU v10.2/MCU/ColdFire_Support/ewl/EWL_C'
make -f EWL_C.CF.mak TARGET=v2/libc
make[1]: `../lib/v2/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v2/pi/libc
make[1]: `../lib/v2/pi/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v3/libc
make[1]: `../lib/v3/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v3/pi/libc
make[1]: `../lib/v3/pi/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/libc
make[1]: `../lib/v4/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/pi/libc
make[1]: `../lib/v4/pi/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/fpu/libc
make[1]: `../lib/v4/fpu/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/fpu/pi/libc
make[1]: `../lib/v4/fpu/pi/libc.a' is up to date.
make -f EWL_C.CF.mak TARGET=v1/libc99
make[1]: `../lib/v1/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v2/libc99
make[1]: `../lib/v2/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v2/pi/libc99
make[1]: `../lib/v2/pi/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v3/libc99
make[1]: `../lib/v3/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v3/pi/libc99
make[1]: `../lib/v3/pi/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/libc99
make[1]: `../lib/v4/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/pi/libc99
make[1]: `../lib/v4/pi/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/fpu/libc99
make[1]: `../lib/v4/fpu/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/fpu/pi/libc99
make[1]: `../lib/v4/fpu/pi/libc99.a' is up to date.
make -f EWL_C.CF.mak TARGET=v1/libm
make[1]: `../lib/v1/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v2/libm
make[1]: `../lib/v2/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v2/pi/libm
make[1]: `../lib/v2/pi/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v3/libm
make[1]: `../lib/v3/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v3/pi/libm
make[1]: `../lib/v3/pi/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/libm
make[1]: `../lib/v4/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/pi/libm
make[1]: `../lib/v4/pi/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/fpu/libm
make[1]: `../lib/v4/fpu/libm.a' is up to date.
make -f EWL_C.CF.mak TARGET=v4/fpu/pi/libm
make[1]: `../lib/v4/fpu/pi/libm.a' is up to date.
if exist EWL_C.CF_CmdLineData rd /s /q EWL_C.CF_CmdLineData
C:\Freescale\CW MCU v10.2\gnu\bin\make: Do not specify -j or --jobs if sh.exe is not available.
C:\Freescale\CW MCU v10.2\gnu\bin\make: Resetting make for single job mode.
Nothing appears to get built.  No file dates change in {Stuff}/ColdFire_Support/wel/lib/v2 and its subdirectory.
What am I doing wrong?
标记 (1)
1,504 次查看
wcc3
If I Clean the coldfire_lib project before building it, it builds well enough to work.
Did notice that the variable __COLDFIRE__ doesn't get defined.  That means I have to change the switches in the ansi_parms.h file rather than the more obvious ones in the coldfire/ansi_prefix.CF.h file, but it does work.
1,505 次查看
wcc3
