CodeWarrior USB TAP problem
2,046 次查看
DanRobinson
MPC5125 tower kit
CW USB TAP
Win7
CW MobileGT 9.2
CW debugger data drop v9.2 build 5125 sp 830
CW build 090311, mpc5125 service pack 1
JTAG config file C:\Program Files\Freescale\CodeWarrior for MobileGT V9.2\USB_TAP_JTAG.txt
target init file {Compiler}PowerPC_EABI_Support\Initialization_Files\52xx\5125ADS_init.cfg
I have CodeWarrior 9.2 Mobile GT installed on a Win7 machine.  When I used the Tools -> Hardware Diagnostics to try to try to write to memory, I get an error "JTAG chain does not contain any debuggable cores".  I have set CW to run as Adminstrator.  'Before I did that, I got an error that I needed to check my JTAG clock speed.
Here is the protocol log
CCS: 0000 : ccs_open
CCS: : ipaddr = 127.0.0.1
CCS: : port = 41475
CCS: : timeout = 10
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 10
CCS: : Error message:
Connection refused
CCS: : port = 41475
CCS: : timeout = 10
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 0
CCS: 0000 : ccs_get_connection_count
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_get_connection_count; ccs_error = 0
CCS: 0000 : ccs_available_connections
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_available_connections; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_delete_cc
CCS: : serverh = 0
CCS: : count = 0
CCS: : ccs_delete_cc; ccs_error = 0
CCS: 0000 : ccs_config_cc
CCS: : serverh = 0
CCS: : config_string = utap:0
CCS: : ccs_config_cc; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_set_timeout
CCS: : serverh = 0
CCS: : timeout = 10
CCS: : ccs_set_timeout; ccs_error = 0
CCS: 0000 : ccs_kill_server
CCS: : serverh = 0
CCS: : ccs_kill_server; ccs_error = 0
Anyone using USB TAP on win7?
标记 (1)
1,208 次查看
DanRobinson
I have also applied the fix from AN4338.  The driver is LibUSB-win32.
