CodeWarrior QVCS fatal alert: protocol_version
Cole_B
I tried to get QCVS running under Linux (Ubuntu 14) and Windows (7). When trying to get the “Frame Distributor Wizard (FDW)” running, the initial link did not work. So I tried following https://community.nxp.com/t5/CodeWarrior-for-QorIQ/QCVS-install-error/m-p/572995#M5983. Using the http://freescale.com/lgfiles/updates/Eclipse/QCVS/content.xml link, I get the following error: Received fatal alert: protocol_version. I tried updating my Java and using Ubuntu 18, but neither worked. Is there another repo I should go to?
yipingwang
Please download QCVS for PA 4.5 installation file from the following link.
https://support.nxp.com/s/case/500Tg00000GJrXMIA1/community-codewarrior-qvcs-fatal-alert-protocolver...
Please install CodeWarrior for PA 10.5.1 first, then open CodeWarrior IDE and install QCVS for PA 4.5 from Help->Install New Software->Add->Archive.
