Cannot get a connection to debug MPC8377erdb board with USB Tap and CW Linux
2,201 次查看
mbr123
Ladies & Gents,
i'm using Codewarrior IDE 5.9.0 build 4781 professional linux edition with latest patches 8.8.3. The MPC8377erdb is running on the ltib version: ltib-mpc837xerdb-20081113.
After compiling the simple "hello world" application, cw tries to connect 4 times to MPC8377erdb board and gives me the following error:
CSSProtocolPlugin::Could not connect to the requested core core #0.
Logfile:
CCS: 0000    :    ccs_open
CCS:        :        ipaddr = 127.0.0.1
CCS:        :        port = 41475
CCS:        :        timeout = 10
CCS:        :        serverh = 0
CCS:        :    ccs_open; ccs_error = 10
CCS:        :        Error message:
Connection refused
CCS:        :        port = 41475
CCS:        :        timeout = 10
CCS:        :        serverh = 0
Connection refused
CCS:        :        port = 41475
CCS:        :        timeout = 10
CCS:        :        serverh = 0
Connection refused
CCS:        :        port = 41475
CCS:        :        timeout = 10
CCS:        :        serverh = 0
Connection refused
CCS:        :        port = 41475
CCS:        :        timeout = 10
CCS:        :        serverh = 0
CCS:        :    ccs_open; ccs_error = 0
CCS: 0000    :    ccs_get_connection_count
CCS:        :        serverh = 0
CCS:        :        count = 1
CCS:        :    ccs_get_connection_count; ccs_error = 0
CCS: 0000    :    ccs_available_connections
CCS:        :        serverh = 0
CCS:        :        count = 0
CCS:        :    ccs_available_connections; ccs_error = 0
CCS:        :        serverh = 0
CCS:        :        count = 0
CCS: 0000    :    ccs_config_cc
CCS:        :        serverh = 0
CCS:        :        config_string = utap:0
CCS:        :    ccs_config_cc; ccs_error = 0
CCS:        :        serverh = 0
CCS:        :        count = 1
CCS:        :        serverh = 0
CCS:        :        count = 1
CCS: 0000    :    ccs_set_timeout
CCS:        :        serverh = 0
CCS:        :        timeout = 10
CCS:        :    ccs_set_timeout; ccs_error = 0
CCS: 0000    :    ccs_config_server
CCS:        :        serverh = 0
CCS:        :        cc = 0
CCS:        :        server_config = 0
CCS:        :        value = 1000
CCS:        :    ccs_config_server; ccs_error = 2
Network timeout
CCS: 0000    :    ccs_get_config_chain
CCS:        :        serverh = 0
CCS:        :        device_list: (size = 0)
CCS:        :    ccs_get_config_chain; ccs_error = 2
Network timeout
CCS: 0000    :    ccs_kill_server
CCS:        :        serverh = 0
CCS:        :    ccs_kill_server; ccs_error = 14
Invalid sequence number
CCS: 0000    :    ccs_delete_cc
CCS:        :        serverh = 0
CCS:        :        count = 0
CCS:        :    ccs_delete_cc; ccs_error = 7
Invalid handle
CCS: 0000    :    ccs_close
CCS:        :        serverh = 0
CCS:        :    ccs_close; ccs_error = 0
Can anybody help me out of this?
Thanks in advance
标记 (1)
1,077 次查看
mbr123
Hi all,
it seems that this problem does not occure if I disconnect and then reconnect the USB TAP from the main pc. But doing this everytime I want to debug a program is very annoying. Every help for a solution is very appreciated.
Thx
