CW7.0 for ColdFire -> debugger
Nouchi
Senior Contributor II
I would like to know how to display local variables and function parameters  in debug data window.
I tried to set to the minimum compiler level optimization, to check "Show Hidden locals" box  without any success, it displays "no local variables"
It worked with CW6.4.
Emmanuel
Message Edited by BugMan on 2008-05-14 09:57 AM
RichTestardi
I think you need to turn off register coloring and rebuild...  This behavior is new for CW7.0.
  Project Settings -> Code Generation -> ColdFire Processor.
One time I found a post on the web indicating the debugger had not caught up to the code generator in this regard, so I tried it, and it worked.
-- Rich
Nouchi
Great!!!
Just works fine.......
