Thanks Daniel,
is there anything I can change to work around this error?
I must say I think you guys have done a good job but my experience of converting old mcp projects to CW 10 so far has been frustrating.
I've been using Eclipse since version 2.x both on Linux (using GNU tools) and Windows (using cross-compiler arm-elf tools). Also I've used Eclipse for C, C++, Java and Python projects.
I'll list some of the issues:
1. Importing an mcp project with Processor Expert fails to import the Processor Expert settings.
2. Importing a classic project with subproject fails to recursively import subprojects (the beta version of CW 10 did manage to do it)
3. 'The system recursive path' includes have got some problems. Despite having "${workspace_loc:/EWL_C.project/include}" under there (as automatically setup by the import wizard), the includes <stdint.h> and <stdio.h> could not be found and I had to manually add the path to the EWL library under "System Path"
4. Other problems with library includes prevent me from building a project. For example "intptr_t" can't be found. I'm going to play a bit with different library models but the best would be just to build our own library, as we did in the old CW.
I'll just ask some more questions about the license, feel free to redirect me to the right places...
We have some perpetual licenses and some annual ones for CW 7.1. Is there an upgrade program to CW 10? How much $$$? Can we keep the same license for CW 7.1 and 10?
Thank you again, I'm doing my best to make it work, being an Eclipse fan. But it's costing us a lot of time...
Cheers,
Emanuele
