CW for PC9S08PT16VLC
2,239 次查看
jaluna
we have received some sample of PC9S08PT16VLC (32 pins)
In what CW should we work for this device? The CW 10.3 does not have support in PE for it.
Juan
2,105 次查看
jorge_plascencia
Hi Juan,
The CodeWarrior for MCU 10.3  does support the device you are working with I have attached the Release notes and also the download links for the software itself: online Installers
I have also added the Video library and the Infocenter for more documentation in case you need it.
2,106 次查看
jorge_plascencia
Hi Juan,
2,105 次查看
jaluna
Thanks for your message Jorge.
At first, I have created the project using the "New Bareboard Project" but this way don't given me the option to choose the package version. Then, later, I have learn how to change the mcu once the project is created. Now, all is fine and working.
Juan
2,105 次查看
jaluna
Hello, is this device supported?
