upgrade codeWarrior 3.0
4,444 次查看
Stormyweather
how can I upgrade codewarrior 3.0 to 3.1??
标记 (1)
1,978 次查看
CrasyCat
Specialist III
Hello
OK in that case you are eligible for free upgrade :smileyhappy:.
Explain that that to your Freescale distributor and you should be fine.
CrasyCat
6 回复数
1,978 次查看
Stormyweather
thanx.... does it cost any money or the upgrade is free of charge?/
1,978 次查看
CrasyCat
Specialist III
Normally upgrade is not free.
CrasyCat.
1,978 次查看
CrasyCat
Specialist III
Hello
Just ask your Freescale distributor.
Please check following URL to find your closest Freescale distributor:
http://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=01098400786959705928692
CrasyCat
1,978 次查看
Stormyweather
I just bought the M68EVB08GB60
and the 13192 RFmodule doughter card
why didn't I get the last version of code warrior?/
instade of v3.0 from 2001!!!!??
1,978 次查看
CrasyCat
Specialist III
Just an additional note on that.
We checked our inventory and replaced all the CD in the boxes with latest tool versions.
However we cannot check inventory from our distributors.
Note that CodeWarrior for HC08 V5.1 is available for download on the web.
This tool comes directly with the appropriate license file for special edition.
That means that downloading CodeWarrior for HC08 V5.x, you will be able to start developing up to 16K of C source code right after installing.
CrasyCat.
1,979 次查看
CrasyCat
Specialist III
Hello
CrasyCat
