symbols not working
symbols not working
Mike_d
CodeWarrior 10.7,  Target is 56F8345 DSC
ZhangJennie
HI Mike,
To work on your problem, please provide me more information:
1. send me your demo project,
2. you debug project in simulation mode or connecting board?
Thanks.
TIC
Mike_d
Attached is a sample project.  No board needed just compile. This was not a problem until I installed the DSC support to CodeWarrior 10.7.  Before I only had Kinetis support and it worked fine.
-Mike
ZhangJennie
I add DEBUG to "#Symbols" tab, then build your project, there is no error from my side. See attached video.
TIC
Mike_d
Can you share your version information?  I re-installed CW with same original results.
-Mike
ZhangJennie
Hi Mike,
I use CW11.
TIC
