strtod() problems
strtod() problems
1,740 次查看
mikey1
I have been building code for the 9S12X processor and only using the integer library.  I now have a need to deal with floating point and so swapped out the lib from ansixli.lib to ansixlf.lib
when I try to use the strtod() function I get the wrong results and the function writes over the top of the string that I am trying to parse at the point where the asci representation of the floating point number ends.
any recomendations?
标记 (1)
988 次查看
mikey1
I just answered my own question.  I had selected the wrong floating point lib.  I should have used "ansixl.lib" instead of  "ansixlf.lib"
I hope this mistake helps someone else
989 次查看
mikey1
