splitting source files in a project into Lib code and App code
1,961件の閲覧回数
Leong
Hi there
I have a larger program that i would like to be able to split into a library (contains drivers, etc.) and application code. I tried to create 2 targets in the project, but it seems the files are shared. Is there a way to tell which file goes which target or is there better way to do this?
I'm using CW for CF 7.1
1,893件の閲覧回数
Leong
Figured out... each Target Configuration has its own Link Order List... but all share the same file list... kind of counter-intuitive...
1,893件の閲覧回数
Leong
