"Remove markers" crashes CW 5.7.0
irob
Contributor V
Anyone use the marker feature in CodeWarrior? It's a very nice way of jumping to spots in your code where you frequent. Sorta like the function list does, only for any spot in the code.
The thing is, the marker feature doesn't record a line number in your code. I think it must be recording some sort of relative location because when you move code chunks around, the markers tend to get lost.
Here's the situation. When you remove them, sometimes CW dies. Anyone seen this?
CrasyCat
Specialist III
Hello
I have never seen that so far.
I would suggest you to submit a service request around that through our on-line support site.
Make sure to attach installed Product information and reproducible steps.
To get Installed products information:
  - Start IDE
  - select "Help" -> "About Metrowerks CodeWarrior"
  - Click on "installed products"
  - Click in Save As , save information to a file.
CrasyCat
CrasyCat
Specialist III
Hello
  - Start IDE
CrasyCat
irob
Contributor V
Done. Will keep the board posted.
chapster
I haven't had this problem but my markers do disappear whenever I copy projects when working on different PCs.  I find the markers very useful so it is annoying to lose them all the time.  Where are they kept?
irob
Contributor V
I agree, chapster. That's annoying. I don't know where those markers are kept. You'll find that even in the same project where the markers are, they will get quickly corrupted as you edit your code drastically. Say, for instance you relocate a function, its marker will get all scrambled.
