No changes on all my global variables in CW V4.6?
ソリューションへジャンプ
2,140件の閲覧回数
Pang
Hi Everyone,
I got a problem with the debugger True-Time Simulation in CW 4.6 (30 day Trial Version). When step in, I can not see any changes on all my global variables declared as followed:
file1.c
unsigned long RamPtr;
file2.c
extern unsigned long RamPtr;
I was unable to see  a change on this variable (in Registers, the value of this variable is changed indeed). Why no display updated automatically? the locals in Data:2 window, work fine.
Thanks a lot for any inputs.
Pang
タグ(1)
1,458件の閲覧回数
CompilerGuru
Please provide more informtion. Normally especially global variables are correctly displayed, so there must be something special in your setup. Try a simple wizard generated project, if it failes, post it here so we see the complete sources.
Also a bitmap showing what you see with some comments what you expect may help. Are your globals actually used?
1,459件の閲覧回数
CompilerGuru
