"Add Watch Expression" in External Memory
ソリューションへジャンプ
2,486件の閲覧回数
Ecap
i work with "Code Warrior 10.2" and "MQX 3.8" on Kinetis K60 target.
I use 512KB FlexBus external memory starting at 0x60000000.
In debug on target i 'm not able to see variables content allocated in external memory.
By "Add Watch expression" debug command i see 0xBABABABA.
There is a way to solve the problem??
Thanks!
1,808件の閲覧回数
konrada
Check the memory configuration in your debug target (reachable from the "Connection" in the Debug Configurations dialog). Is there a .mem file? Does it describe your memory layout correctly?
2 返答(返信)
1,809件の閲覧回数
konrada
1,808件の閲覧回数
Ecap
Yes there is the link to .mem file.
I have changed it according to my memory and now it works! :smileyhappy:
Many Thanks!
