how to use full chip simulator for the project created by myself?
1,637 次查看
tongjifres
hi all,
I never used simulator of codewarrior before, seems l had some problems.
I am using hc908ab32 and codewarrior v3.1, and I didnt use the new project wizard to creat the project but hco8 stationery-legacy-simulator-c generic. After I debug it, i find there is no memory at frome 0x0000 to 0x0040, where should be the image of i/o and i/o register.ect.  I defined it in my own reg.h as
 #define  PORTA_REG  (*(volatile unsigned char*)(0x0003))
 like this.
I think its right. why  no memory  when i start it in simulator?
And I also creat project use wizard, i found the memory was ok. and there is port pins module Clock module SCI module.etc under PEdebug^
can anyone kindly tell me the reason, or tell me how can i find the information or book of codewarrior's simulator.
warm regards
tongjifres
标记 (1)
909 次查看
CrasyCat
Specialist III
Hello
I already answer this question in following thread.
Please try to avoid cross-posting in the future.
Thanks for your understanding.
CrasyCat
910 次查看
CrasyCat
Specialist III
Hello
CrasyCat
