how to generate a lib
1,976 次查看
jackwan
Dear sir,
             I am using the codewarrior to develop on MPC5566. I want to generate a static link library for BSP and drivers.Do you know how to generate it by codewarrior? And how to link the static link library when develop the application by codewarrior? Many thanks!
BR,
1,840 次查看
martin_kovar
Hello Jack,
about static library creating, open project settings, click EPPC Target, and change Project Type to Library.
About linking, create you own library as I described above and simply drag and drop this library into Runtime folder of the project you would like to link the library to. Now you can call functions from the library.
Hope this helps.
Martin
1,840 次查看
jackwan
Hi Martin, Got it. Many thanks for your help!
万宁
邮箱:[email protected]
签名由 网易邮箱大师 定制
