Hello
If you want to reserve a page of flash for your application, just make sure to remove any occurrence of this page in the.PRM file's PLACEMENT block.
Your original placement block might look as follows:
Code:
PLACEMENT
DEFAULT_RAM INTO RAM,RAM1; _PRESTART,
STARTUP, ROM_VAR, STRINGS, VIRTUAL_TABLE_SEGMENT,
NON_BANKED,
DEFAULT_ROM, COPY INTO ROM;
PAGED_ROM INTO PPAGE_0,PPAGE_2,PPAGE_4,PPAGE_5,PPAGE_6,PPAGE_7,ROM1; _DATA_ZEROPAGE,
MY_ZEROPAGE INTO Z_RAM;END Let's say you want to reserve PPAGE_0 to store your data in your application. Then modify the placement block as follows:
Code:
PLACEMENT
NON_BANKED,
PAGED_ROM INTO PPAGE_2,PPAGE_4,PPAGE_5,PPAGE_6,PPAGE_7,ROM1; _DATA_ZEROPAGE,
MY_ZEROPAGE INTO Z_RAM;END CrasyCat
