cw10.7 Special Edition - code size limitation
1,265 次查看
jeannoelboutevi
Hello
I have several xxxx.c modules that are Embedded in my program.
At debug stage I got the following error concerning one of them:
code size 1105 > 1024
That would means a limitation to 1024 oct for each  xxxxxx.c modul.which are included in the program.
My question :
What are the rules used by this cw10.7 Special Edition to limit code size?.
Many thanks
Jnb
标记 (1)
1,169 次查看
ZhangJennie
Hi Jnb,
The special edition code size limit relies on what target you are working with.
Please check your target part number and refer this doc
http://www.nxp.com/assets/documents/data/en/fact-sheets/950-00437.pdf
If you can't figure it out, please contact me again.
Jennie Zhang
