bad character sequence encountered
I am using CodeWarrior for MCU Version 10:.2 Build 120126 with XBee-PRO 900HP DigiMesh
(SB3). When I try to debug the Button Polling Example, I receive a message that bad character
sequence encountered when stepping through the code for Sources \ CPU \ System.c.
It does not like the @ sign.
volatile app_rst_casuses_t app_rst @0x200;
/* Reserved @0x202
volatile bl_rst_casues_t bl_rst @0x204;
/* App use 6 bytes @0x202
volatile uint8_t haddr_16[2] @0x20C;
volatile
uint8_t haddr_64[8] @0x20E;
There are no compile errors encountered.
The same error occurs on multiple projects.
The preprocess of System.c resolves the waning messages and creates Systemxxxxxxx.c
Any suggestions?
