avoiding make file in codewarrior
1,788 次查看
manzoorquazi
How to avoid make file while building code in codewarrior. We need to make code system independent.
1,659 次查看
TICS_Fiona
Hello  Manzoor
Are you using the makefile generated by CodeWarrior? Please check whether relative paths rather than absolute path are generated inside of the makefile. What is the CodeWarrior version you are using?
For Classic CodeWarrior, please:
1) Start the IDE and click on Help | About Freescale(Metrowerks) CodeWarrior.
2) Click on Installed Products
3) Provide us all info displayed. Or you can save them in a txt file.
For Eclipse CodeWarrior, please:
1) Start the IDE and click on Help | About CodeWarrior Development Studio.
2) Provide us the info displayed.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
1,660 次查看
TICS_Fiona
Hello  Manzoor
Best Regards
Fiona Kuang
1,659 次查看
ZhangJennie
what's your chip part number?
what's your CW version?
Jennie Zhang
