When a variable satisfies some condition
5,953 次查看
smecolive
When a variable satisfies some condition, I want pause or break,it is like a trace function on a variable,are there any way?thanks a lot
4 回复数
5,941 次查看
ZhangJennie
Hi smecolive
You can use condition breakpoint.
see attached video. program stops when variable i equals 100.
Hope this helps,
Jun Zhang
5,937 次查看
smecolive
感谢回复。对于条件断点的相关使用我已经弄清楚了,但是我想知道的是对于单一变量(或者信号)如何设置这种类似条件断点的监测,当变量(或者信号)达到某种条件时中断或者输出特定信息。另外,类似这种的CW的功能的使用视频还有更多吗,我以及身边的同事想更多地学习Code Warrior的使用,十分感谢!
5,928 次查看
ZhangJennie
If you want to monitor variable or memory, I suggest you using watchpoints.
You can set a watchpoint from the:
• Breakpoints view
• Memory view
• Registers view
• Variables view
For more information, see attached doc.  3.36 Watchpoints.
The video I sent you is made myself for your question. So no additional existing videos.
Have a nice day,
Jun Zhang
5,925 次查看
smecolive
thanks for your reply,I will read the file you sent me.
Best regards.
