When I installed codewarrior V10.6 in windows XP, error"Failed to create Java virtuan machine" occurred.
1,713 次查看
zhouzhuoqiang
When I installed codewarrior for MCU V10.6 in windows XP, during installing process, error "Failed to create Java virtual machine" occurred. How to solve it?
Thanks a lot!
5 回复数
1,461 次查看
ZhangJennie
normally this is because of the low computer memory.
is this problem happened during inatall halfway or after installation?
How about your computer system hardware configuration?
Jennie Zhang
1,461 次查看
zhouzhuoqiang
3.32GHz, 504M RAM
1,461 次查看
ZhangJennie
CW10.6 needs at least 2GB RAM. 504M is not enough. see CW system requirement:
can this help you?
Jennie Zhang
1,461 次查看
zhouzhuoqiang
Thanks a lot!
1,461 次查看
ZhangJennie
you are welcome!
Jennie Zhang
