Step over is now step into
2,486 次查看
pgillaspy
Using CS 11.1.  What has happened now??  In debug mode, the step over icon is now always step into!!! Now there is no way to step over source lines of code.  What to do to fix??
2,028 次查看
ValTek
Hello, I have the same issue on the S32 Design Studio 3.5 update 11 (same on update 9) using the PEmicro debugger (version 5.7.8). Creating new project didn't solve the issue...how to solve?
2,476 次查看
ZhangJennie
HI @pgillaspy
I couldn't reproduce your issue.
To identify the problem is associated with a project or workspace, I suggest you create a NEW project under a NEW workspace. See how it works?
Jun Zhang
