Standard Deviation Inbuilt Function available in math.h?
1,209 次查看
utsavikalpesh
Hi.,
I am working with CodeWarrior v10.6 and of MQX v4.0.
I want a function that is calculating Standard Deviation. is there any provision in am math.h .
I tried to search it on math.h but helpless to get it.
Utsavi Bharuchwala
949 次查看
ZhangJennie
Hi Utsavi Bharuchwala,
from what I know, math.h doesn't have a function to support standard deviation, but it can support some other floating point calculation, for instance sqrt() -- Square Root Calculation.
to get floating point calculation working, we must set compiler tool:
Tool Settings->Librarian->Model->c9x
The EWL library has a smaller footprint but doesn’t support floating point calculations.
I suggest you refer this thread for more information:
Floating point calcs on Kinetis CPU CW 10.1 MQX 3.7
Jennie Zhang
949 次查看
utsavikalpesh
Hi Jennie,
Thanks for reply.
Utsavi Bharuchwala
