Simple FLASH access in C language, for 9S08GT, it's possible?
1,600件の閲覧回数
hernanEche
It's posible from C language to simple write/read a byte in FLASH  (as if were an EEPROM)?
The micro is 9S08GT
I need to store a value that
  • Keep value after power off
  • Can be changed in runtime
The normal answer is : an external EEPROM
but, can it be done with FLASH and avoid external EEPROM?
タグ(1)
951件の閲覧回数
peg
Senior Contributor IV
Hello and welcome to the fora.
Yes you certainly can do this.
Do a search in the 8 bit microcontroller forum for the multitude of threads on this subject to be found there.
Good Luck!
952件の閲覧回数
peg
Good Luck!
951件の閲覧回数
hernanEche
I am glad that is possible, I will search those threads, thanks!
