SPI example
SPI example
5,215 次查看
juliancox
Does anyone know where I can download an example project for the S08 MCU using SPI. In my case I am trying to communicate with a TI ADS1120. BTW. Why is the Processor Expert component shown as a SynchroMaster while its property (Channel) is shown as SPI? Can this component be anything other than a SPI?
标记 (2)
4,964 次查看
vicentegomez
For the QE the sample code I believe was created on code warrior 6.x
For the P family was used code warrior 10.x so for these samples you should not have any problem to open it on CW 11
4 回复数
4,964 次查看
juliancox
Thanks for your help
4,964 次查看
vicentegomez
Can you tell me the S08 that you are using?
You can check some code for the spi on the following link
https://www.nxp.com/docs/en/user-guide/HCS08QRUG.pdf
https://www.nxp.com/docs/en/user-guide/QE128QRUGSW.zip
Also for a news S08 like the S08P family, you can check the following link:
Please check the lab 6
https://www.nxp.com/docs/en/supporting-information/TWRS08PT60LAB.pdf
https://www.nxp.com/docs/en/supporting-information/TWR-S08PT60-LABS.zip
I hope this will help you
regards
4,964 次查看
juliancox
Thanks for the information, but I cannot import any of the projects into CW 11.0. Which IDE was used to create them? FYI - I am using an S08 QE8, but I also have  DEMOQE 128 board.
So far I have managed to confirm that I can send data (ProcessorExpert SendChar), but when I try to receive data (ProcessorExpert RecvChar) there is no serial clock and the operation returns a overflow error. Any ideas?
4,965 次查看
vicentegomez
